Creating ready to use empty mdv or flp files for whichever emulator
mystikshadows
Post by mystikshadows »
please move to a more appropriate thread if there is one. :)
It's all in the subject lol. forgive my request. but i really have no idea how to. help :) thank you :).
desin
Re: Creating ready to use empty mdv or flp files for whichever emulator
Post by desin »
QLay | QLay2 | QL2K | QPC1 | QPC2 | Q-emuLator | QDOS4Amiga | QDOS Classic Amiga | QLem Atari | SMSQmulator | MESS | MIST/MISTer | uQLx | QDOS Classic Q40
take your pick
mystikshadows
ok...how? say in QLay2?
I'm in it right now and I can't see where I can create them.
Just get an existing MDV ot FLP image file attach it to the emulator in question and FORMAT the image.
Image files are just that - files.
To be accepted by the drivers they need to have some specific length, evenly divisible by the sector length to avoid confusion (and of course with a maximum size - no mdv image with 1000 sectors, please). You should even be able to create them with a simple S*Basic program. Once created and installed with the image drivers, they need to be formatted just like a real device.
tofro wrote: Thu Dec 12, 2024 5:05 pmYou should even be able to create them with a simple S*Basic program.
Would be interesting to see that.
mystikshadows
yes it would. :)
CHALLENGE lol
I just make a copy of the MDV image and attach it to Q-emulator in a Drive and fornst the MDV image.
Or Q-emulator can create FLP images.
But why not use MDI and FDI to create the image file, usung the MAKE_MDI or MAKE_FDI
MDV images are not standard, MDI can convert MDI to MDV image using the CONVERT2_QLAY or CONVERT2_QEMU
Which can automated in a SBASIC program.
I can't remember how to create a QLAY.MDV file in the emulator itself - it's a long time I had a copy set up to use.
The QLAYT program (one of the tools accessories) could create a .MDV image. I vaguely remember it was via a command line switch and you had to make a text file with a list of files to be made into a .MDV file. The QLAYT.MAN file will most likely explain exactly how. I'm guessing from memory with the following so I might be wrong:
QLAYT -C listname.txt
I think the '-C' stood for CREATE (but please read QLAYT's manual in case I'm wrong). By default, it will create a file called QLAY.MDV although there is another option to change the .MDV name used. Also, I can't remember where it places the file, maybe in the same folder as the list file?
Sorry I couldn't be more specific, this is all from memory from when I last used it a few years ago. At least you'll know where to look for the info now, I hope.
Well, there is always the MAKE_MDI command from the MDI driver. Creates a working, empty image with a single command. Sometimes it's really useful to read the manual.
