Basic Reporter v2.02
I tried to use Basic Reporter v2.02 and I receive errors when I try to list to screen.
Tested on QPC2 (SMSQ/E + Launchpad) and also on QEmulator with JS ROM and Minerva ROM and nothing else loaded
@Dilwyn, can you offer some guidance on this?
Re: Basic Reporter v2.02
Here is an untested fix for the BASIC Reporter bug. Done very quickly, it seems to work, but I don't have the time to test for any knock-on effects accidentally introduced.
It was a weird bug which only existed while Turbo compiled, which is why it was a bit hard to debug. I've fixed it (I think) by writing the screen heading code a little differently.
If it seems to work for you Andrew, I will add this version to my website.
EDIT: Here's version 2.04 which improves on a couple of other lesser issues.
basrep204.zip
BASIC Reporter v2.04
(46.54 KiB) Downloaded 64 times
