Video cable compatible with all Scart TVs
Robbizz
Post by Robbizz »
Hi guys, I found some time to spend with my QL and I built a Video Scart cable myself. I followed the diagram below (the sockets are seen from the front, NOT the solder side). It works very well with a couple of TVs at home but on a small TV/Monitor (where among other things I would like to always keep it connected to my QL), it doesn't work: on the latter TV there is a message "no signal" when I turn it on and then - when I press F2 - I see a red image out of sync. The resistors are 390 Ohm. What do you think it could be?
Re: Video cable compatible with all Scart TVs
Hi Robbizz!
[Edited to correct SCART pin numbering in original post]
I've had success creating a number of QL -> SCART cables over time, based more or less on the really useful site:
http://www.fruitcake.plus.com/Sinclair/ ... ableQL.htm
I guess you might have used the same site and, like me, you've used that 'trick' to use the Comp. PAL Video (QL pin-1) output to drive BLANKING (SCART pin-16) as a convenience to present c. 1V+ and thus trigger the TV/Monitor in to RGB mode (vs Comp. Video.)
However, as per that site, I also add the 330ohm resistor in series with the TTL CSYNC signal in to SCART pin-20 (Video-in), effectively lowering the CSYNC signal presented at Video-in to around [75 / (330 + 75) x 5V =] 0.93V pk.
Some TV/monitors might be sensitive to the TTL level appearing on pin-20, so I recommend adding that series resistor to effectively lower the pk voltage present at Video-in.
Again, referring to the above site, I've never needed to drive the FUNCTION pin (SCART pin-8), but again, some TVs might be fussy, though the effect you describe doesn't sound relevant to driving this pin.
Let us know how you get on!
Robbizz
Post by Robbizz »
martyn_hill wrote: Sat May 11, 2024 8:18 pm Hi Robbizz!
However, as per that site, I also add the 330ohm resistor in series with the TTL CSYNC signal in to SCART pin-18 (Video-in), effectively lowering the CSYNC signal presented at Video-in to around [75 / (330 + 75) x 5V =] 0.93V pk.
Some TV/monitors might be sensitive to the TTL level appearing on pin-18, so I recommend adding that series resistor to effectively lower the pk voltage present at Video-in.
Thanks for the suggestion. I tried to put a 330 Ohm resistor in the point indicated by the arrow, but unfortunately I still receive no signal (when there is the initial F1-F2 screen) and then I see the screen as per the disturbed photo (exactly like before).
Note that with the same cable, on my TV at home, it works perfectly (see last photo).
I don't think that the Samsung TV has problems managing RGB signals, because I tested it using an Atari ST with Scart cable and it looks good.
Hi again Robbizz!
OK, so all I personally can think-of is that this monitor doesn't like the QL's 'over-scan' timing and is struggling to sync properly.
(BTW, as you observed, I misnamed the SCART Video-In pin - yes,its pin-20, not 18.)
Keep us posted :-)
Probably not very relevant here, I don't know, there was sometimes an issue if a Gold/Super Gold Card was involved. One eBay supplier made different SCART monitor leads for QLs with Gold Cards or Super Gold Cards (maybe both, can't remember).
I've had a look for the explanatory paperwork which came with the lead, but can't find it - it's probably in one of the computer junk boxes in the attic with the SCART leads, as my QLs now have the VGA monitor adaptor devices instead. I think it was as simple as either an extra resistor or a different resistance on one pin.
If I manage to find it I'll post it here. Hope that saying this will make someone remember what the difference was!
Oops, minutes after my first post I remembered the cables I mentioned came from Retro Computer Shack:
https://www.ebay.co.uk/itm/260814300633 ... R8CBqv3uYw
Further down that page is the explanation regarding the extra resistor for (Super) Gold Cards:
Retro Computer Shack SCART leads
Those leads cost £14.49 including postage.
They use the CSYNC as ram refresh signal, so squashing it to zero volts by connecting to SCART does not go well. I reported the issue to RCS and he fixed future cables!
XorA wrote: Tue May 14, 2024 5:12 pm
Thanks XorA, that's refereshed my RAM a little too.
HI,
I use the cables from Retro Computer Shack, all very high quality and work on the QL RGB output to a SCART input on TV Monitor.
