QL / PASCAL
QL / PASCAL
Hi.
Which is the best Pascal compiler available under SMSQ/E Extended QL ( SuperGoldCard, Minerva ...).
Thanks in advance.
M.
Thanks in advance.
M.
Re: QL / PASCAL
Prospero Pascal. Definitely.
It has the diadvantage that you have to load the compiler runtimes as a ROM file using EPROM_LOAD or LRESPR (or have the ROM in the ROM port on a BBQL), both for using the compiler and the generated programs.
Metacomco Pascal (second best IMHO) uses a ROM as well, but wants it for the compile stage only.
ComputerOne Pascal doesn't run on SMSQ/E.
- NormanDunbar
- Forum Moderator
Re: QL / PASCAL
I wonder if Free Pascal could be ported to our beloved QL?
https://www.freepascal.org/develop.html
How hard could it me I wonder. There appears to be a M68K version in the development tree!
Re: QL / PASCAL
Where can i find the manual for Prospero Pascal? On Dilwyn's site i could find only the Fortran manual
Re: QL / PASCAL
Hi.
I found this manual on archive.org.
M.
M.
- Prospero_PASCAL.pdf
- (623.52 KiB) Downloaded 471 times
Re: QL / PASCAL
Thank yougenetika wrote:Hi.
M.
This seems to be the manual for Prospero Extended Pascal for OS/2, so it has no QL specific info.
Re: QL / PASCAL
I found it !
The Prospero Pascal manual can be found in THE_DISTRIBUTION - directory \xcl\prs\Documentation
The scanned version is 24.5Mb so it is to large to load it here
There also is a html version - but it is OCRed withh lots of errors
Re: QL / PASCAL
A few issues ago with SMSQzine, I did a review of both Computer One and Prospero Pascal. Computer One is only for QDOS (UQLX or Q-emulator) but Prospero will work with SMSQ/E. Again, details are in SMSQzine. When they were both release I was keen to use them. I had used Metacomco Pascal in college. I actually ran into a bug and tried to get Metacomco to fix it. I called the Scotts Valley, CA office (the nearest one) and they were "yea, I think we have a QL around here somewhere."
Tim
Tim
Re: QL / PASCAL
I have had a look at the Prospero Pascal Manual, while the PDF is OCRed, it is not been done very well.
I have copied all the OCR text in LibreOffice and am reformatting the document, then I can export it has a PDF, though of there are diagrams, they may have to be images in the PDF.
I am not sure how much time this wll take..
I did a similar thing for Computer One Pascal, but never released the converted Word file.
Re: QL / PASCAL
Hi Norm,NormanDunbar wrote:I wonder if Free Pascal could be ported to our beloved QL?
I had a look at Free Pascal, it looks to be written in Pascal, so maybe the existing QL Pascal compiler could help with the compiling of Free Pascal.
