QXL2 and PC Motherboard - SOLD
Sell your QL items here!
QXL II Hardware QL Emulator card
CPU: 68EC040RC25 CPU Clocked at 25Mhz
RAM: 8Mb
Screen Resolution: 512x256, 640x350, 640x480 or 800x600 pixels
Ports: QL Network ports
Comes complete with SMSQ v2.47 and SMQ/E v2.57
QXL Display
QXL Display
QXLII and SMSQ Disk
QXLII and SMSQ Disk
Note: Up to date versions of SMSQ/E can be download from:
http://www.wlenerz.com/smsqe/
Manual can be downloaded from:
http://www.dilwyn.me.uk/docs/manuals/qxl.zip
QL-compatible card for a PC with an ISA card slot, requires MSDOS or Windows
ISA MOTHERBOARD:
PC Motherboard
PC Motherboard
Super Micro Motherboard:
SiS 530 MICRO ATX
Mother Board: SUPER SOCKET 7
CPU: AMD K6 500
CPU SOCKET: 462/a
MEMORY: 512 MB SDRAM
PC Backplate
PC Backplate
On board Interfaces:
1 x ISA
2 x PCI
2 x IDE
1 x FLP
SOUND: Mic, Line In, Line Out
1 x Parallel Port
2 Serial COM ports
VGA
USB
BACK PLATE
Mother tested and works perfectly.
Price:
QXL2 : £200
PC Motherboard: £50
Last edited by Derek_Stewart on Mon Feb 05, 2018 10:11 pm, edited 1 time in total.
1024MAK
Re: QXL2 and PC Motherboard
Post by 1024MAK »
I'm interested in the QXL II
I'll send a PM
Mark
:!: Standby alert :!:
“There are four lights!”
Zarchos
Post by Zarchos »
I am interested by the lot.
How much to ship to France ?
Owner of various QLs including accelerated beasts, and also a happy Q68 owner ;)
Zarchos wrote:I am interested by the lot.
Sorry it now sold.
I have 2 QXL cards which could be built into a Black ATX case.
Zarchos
Post by Zarchos »
Sorry it now sold.
I am interested.
Hi Derek
Derek_Stewart wrote:I have 2 QXL cards which could be built into a Black ATX case.
What was the spec of the QXL (as opposed to the QXL II you originally posted)? What price did you have in mind?
Is there still one unit left unclaimed?
Re: QXL2 and PC Motherboard - SOLD
The QXL models are:
QXL
68EC040RC40
20 Mhz
QXLII
68EC040RC50
25Mhz
Memory is upto 8Mb.
I used to use the QXL as a QNET server to the Q60 or QPC2 via SERNET.
I have fitted the 68RC040 with FPU which works well. This is the same CPU as in the Q40.
I have not put the remaining QXL cards up for sale due other hardware projects. But I have sohrced some Black ATX cases which could uded with the QXL and the K6 motherboard.
Hi again Derek
Sorry, I got a bit lost in this thread - could you confirm which QXLs are still available, and at what cost?
I'm definitely interested in one QXL (or QXLII) - I've still got an ISA mobo sitting around somewhere.
M.
Silly question, but aren't the CPUs running at full speed, with the clock being half the frequency of the CPU and a tick being on each change of the CLK? Or are they really running at half speed?
Hi Dave,
The 68040 CPU divides the system clock by 2, so on the QXL running at 20Mhz has a 40 Mhz oscillator fitted. The QXL II has a 50Mhz oscillator fitted to run at 25Mhz.
There are 68040 to 68060 adapters designed in the Amiga world that allow a 68060 CPU to be fitted into a 68040 socket. The main problem is that the 68040 runs with 5v and 68060 uses 3.3v. So the adapter has 2 boards separating the 5v from the 3.3v sections.
Whether this would work on a QXL II is unknown. I have 2 kits to make up to see if this is the case. The thought of a QXL II running at 50Mhz with no alteration to the QXL board, is worth trying.
There maybe issues with the QL Network timmings.
