Solved: QPC2/SMSQ: Isn'nt there no more EDIT command?
ql_freak
Post by ql_freak »
Is there no EDIT command in SBASIC which allows (as on an original QL) to edit a line in channel #0 of the SuperBASIC Interpreter.
If I enter EDIT or EDIT linenumber, the TK2-Screen-Editor is started.
How can I edit a line in channel #0, so that I can make a command from a S(uper)BASIC line?
I have a command in my boot file (open#3,'CON_512x256a50x308') to edit my boot file in a large window. But when my boot file fails, this statement will not be executed. On a normal QL I would use EDIT line_number_of_the_open_statement and then (the statement is editable in channel#0 of SuperBASIC) delete the line number and can execute it as a command.
I found no way, to do this in SMSQ on QPC2.
EDIT:
I have found the trick:
EDIT line_number
then press F10
and afterwards ESC to leave the TK2-Screen Editor
The line is stuffed into the Hotkey Stuffer buffer without the line number ;-))) and you simply can press the normal:
ALT+SPACE
to stuff it into channel#0 :-)
Re: QPC2/SMSQ: Isn'nt there no more EDIT command?
F10 within the ED editor copies the current line into the hotkey buffer. You can then paste it into #0 by using Alt+Enter.
ql_freak
Re: Solved: QPC2/SMSQ: Isn'nt there no more EDIT command?
Post by ql_freak »
Hello mk97,
I was too late ;-) But thank you.
Really a great forum!
There are plenty of useful hints and tips on the ED command in the SBASIC/SuperBASIC Reference Manual
