Lubuntu
Mr_Navigator
QL Fanatic
Lubuntu
Post by Mr_Navigator »
I wont bore you with how I got to this stage, suffice to say, my old and trusty Laptop has been given a dust-off as I found it while packing. Windows bloat-ware has kept every operation to a snails pace, even after a clean install, wiping and formatting the drive. I have in the past tried installing Linux as a look and see, and things always ran fast and smooth but the stumbling block was the wireless connection as Linux put a wrapper around the Windows driver for the particular hardware I have. Its a Medion Laptop, which I bought in Woolworths, yes Medion (who?) and Woolworths (who?).
Now in the past my experience with the Raspi and uQLx came to a grinding halt and thats a future project, so my experience is non-existent. Most of the Linux guides assume a working knowledge of Linux, which I don't have. Anyway after a quick search on the internet for the top ten Linux Distros for 2014 (I know all the lingo now woohoo), Lubuntu came up trumps as a light package especially for older laptops. Downloaded, installed and runs fine especially with my newly acquired and tiny USB WiFi dongle http://www.ebay.co.uk/itm/WIFI-150MBPS- ... 1023374826 it connects with no problem at all.
Great, Chrome installed (I don't like Firefox, but that's my preference) I thought, OK QL time, what can I install. SMSQmulator, it runs on JAVA and in Linux, downloaded, un-archived, read the instructions/readme, Yes it has been tested/ran on Lubuntu, great I thought. downloaded the correct JAVA package, followed the instructions on the JAVA website for installing.
So where I am now, is here.
Un-packed JAVA, unpacked SMSQmulator, double clicking on the SMSQmulator.JAR file just opens up another un-archive option with more folders and files, I don't think I am supposed to do that, but as a LINUX newbie/I know nothing and its all confusing, I am not sure what I am doing wrong or what to do next.
Is there a dummies guide to this process at all?
Anyone?
Re: Lubuntu
Lee,
probably the easiest one (without referring to a lot of desktop re-configuration):
Use an editor (like gedit) to write the following script
#!/bin/bash
java -jar <path-to-SMSQmulator>/SMSQmulator.jar
Save it to a convenient place and make it executable from your file manager application.
A simple double click from the file manager on that script should get you going then.
If that doesn't work, probably some of your PATH needs some tweaking.
Re: Lubuntu
As root run the command
apt-get install openjdk-7-jre
Then you get the version of Java 7 integrated with your desktop, then just double clicking on .jar files works.
Almost always check for a package on your distro before downloading on linux.
Re: Lubuntu
General rule for linux is 98% of the software you want/need is available from the package manager directly. You don't download like you do in windows.
On Lubuntu there should be a GUI to the package manager, called Software Something probably.
Mr_Navigator
QL Fanatic
Re: Lubuntu
Thanks T, are the <> significant?
Re: Lubuntu
Mr_Navigator wrote:Thanks T, are the <> significant?
Oops, no - were just intended to mark a placeholder.
replace <path to...> with the location where you put SMSQmulator, like "/home/navigator/Qmulator/" (without the quotes). The whole thing should then be the complete path to the .jar file.
Re: Lubuntu
In coder terms <> means insert stuff here, you replace the comment and the <> marks.
Mr_Navigator
QL Fanatic
Re: Lubuntu
Thanks guys, the reason I asked is that I have tried both of your suggestions and none of it worked :(
I am trying the package manager now to see if that helps
Its called Synaptic Package Manager for your information
Re: Lubuntu
Well I tend to use Gnome or KDE as they are fully integrated, the desktop environment in Lubuntu is much rougher around the edges.
Re: Lubuntu
Oh and if you have installed openjdk-7-jre then java -jar SMSQmulator.jar on command line inside your unpacked zip file should always work.
You can then work backwards from this to work out what is going wrong with the script.
