Superbasic Syntax rules for Textpad
If anyone has the Textpad editor for Windows and would like to use it to edit QL SuperBASIC programs (with user definable syntax colouring etc) I've added a copy of SuperBasic.syn from Laurence Reeves (author of Minerva) to my website. There is a link to it from Laurence's website at http://www.bergbland.info but it's a broken link, however, luckily I had saved a copy of it some time ago which happens to still be on my PC.
To use it, unzip the superbasic_syn.zip and place the file called superbasic.syn in your "Program Files" for TextPad, inside the "Samples" folder. Textpad can be downloaded from http://www.textpad.com
Download it from http://www.dilwyn.me.uk/basic/index.html (near the bottom of the page with the other syntax rules systems).
