Well I fitted my QL-SD, it is as predicted in manual unstable with SGC.
Looks like I need to get some expansion RAM, mine is lost in storage somewhere.
Here are the pics.
https://plus.google.com/102707388912782 ... cEB3BWRpZF
QL-SD Fitted
Re: QL-SD Fitted
Thank you for posting this.
Do You feel I should add more warnings about GoldCard and SuperGoldCard?
If you like to get an image for 128K then just tell me.
Kind regards
Paul
Kind regards
Paul
- XorA
- Site Admin
Re: QL-SD Fitted
No there were plenty of warnings about the SGC incompatability and I was well aware of it, I had just forgotten that my memory expansion was in storage when I ordered it (I was so excited at the prospect).
A 128k compatible image would be cool until I can sort myself out with memory expansion.
I must say I am impressed with device so far, nice and easy to fit, goes into microdrive slot nice and easy. Manual is awesome.
I did not quite understand the bit about Q-Emulator and BDI files, is it saying if I copy a BDI file somewhere in Q-Emulator as it stands now I can write files to it?
- vanpeebles
- Commissario Pebbli
Re: QL-SD Fitted
Just fitted mine! Working too, pics to follow. Currently it's running with a german keymap so I need to work out how to change that. Not tried much else yet!
dir sdc1_ goes woosh!
- vanpeebles
Re: QL-SD Fitted
I don't have a Trump Card - I have a 512K expanderam which has some faulty memory chips (anyone want it?) and a couple of dead end PCML RAM expansion cards - think they are only 256K from memory - they don't have a through connector.
- XorA
- Site Admin
Re: QL-SD Fitted
Actually if I could make a deal with you for one of those other ram expansions as well, then I can get QL-SD running while repairing expanderam!XorA wrote:Hi Rich, would love that expanderram if its normal type ram chips!
Re: QL-SD Fitted
XorA - you have a PM - yes, it is standard RAM chips (41256P-15) - although I may have spotted the problem - half the chips are MB81256-15 (no real difference), but two are MB81257-15 ....
It is a Miracle Systems expanderam - there is the metal case for it, or the rarer (taller) plastic case - let me know which you want
