Make a bootable PE disk
radastan
Post by radastan »
Hi all,
I copy to a disk:
- Toolkit 2 rom
- PTR_GEN
- WMAN
- HOT_REXT
- QPC1 (¿Only one file?)
Then, I make a boot file that load all of them in memory (first Tookit 2, then PTR_GEN, ..., but NOT QPC1). All OK, all of them in memory.
¿And now? ¿How can I boot PE with QPC1?
Re: Make a bootable PE disk
I presume you mean QPAC1 - not QPC1 (QPC1 was the forerunner of QPC2 a windows emulator) !
There are 6 different task programs in QPAC1 - Alarm / Typer / Calculator / Calendar / Sysmon and Clock
Have a look at the manual - http://www.dilwyn.me.uk/pe/QPAC1.pdf
radastan
Post by radastan »
RWAP wrote:I presume you mean QPAC1 - not QPC1 (QPC1 was the forerunner of QPC2 a windows emulator) !
Yes, is QPAC1 (personal remember note: format and reinstall brain).
I load Toolkit II and the three files required for PE in memory... and now? how can I boot PE with QPAC1?
I didn't find in QPAC1 manual how to boot environment, and ask about a configuration file QPAC1 zip file doesn't have (only contain one file named QPAC1).
radastan,
loading PE into memory is, as you have experienced, just about half of the job. What this does is just placing a number of executable THINGs in memory, ready to be activated.
Activation of PE Things is done using hotkeys and HOTKEY System 2. Best read through http://www.kilgus.net/qpc/QPC_Concepts.pdf
in the chapter about HOTKEY system 2, Page 44 onwards.
(This relates to SMSQ/E, but should in most parts also be applicable to HK on QDOS. The only publicly available document on EE usage that I know, however)
You will then want to come back with more questions ;)
radastan
Post by radastan »
tofro wrote:radastan,
Ok, I know now that a combination of keys will bring me an application on screen.
¿How to load QPAC1 and bring something to screen? only want a example, the rest I will investigate.
Hmm there is some confusion here.
For QPAC2, you use LRESPR flp1_QPAC2 and then use commands like:
ERT HOT_WAKE('f','Files')
to launch the files Thing when you press ALT + f
However, QPAC1 is different.
There is not just one file for QPAC1 on the download on Marcel's site - it actually creates a level 2 directory structure (which q-emulator is not very good at!)
For example - attach the zip file to slot 1:
DIR flp1_
should show:
QPAC1 ->
meaning this is a parent directory.
Unfortunately, in q-emulator, this just shows as
QPAC1
DIR flp1_QPAC1_
will then show:
QPAC1_alarm ->
QPAC1_calc ->
QPAC1_clndr ->
QPAC1_dig ->
QPAC1_sysmon ->
QPAC1_typer ->
These are all sub-directories - again not obvious from within q-emulator for some reason.
DIR flp1_QPAC1_Alarm_
will then show:
QPAC1_Alarm_English
QPAC1_Alarm_French
QPAC1_Alarm_German
These are the executable versions for the different language variants of the Alarm program.
You can then add these to your boot with:
ERT HOT_RES('a', 'flp1_QPAC1_alarm_english')
For example, then press ALT a to launch the alarm program.
What is missing is the original boot file (although that did not cope with multiple languages):
1000 drv$='flp1_'
1010 WINDOW #0,512, 42,  0,214: BORDER #0,1,4*9+192
1020 WINDOW #1,256,182,256, 30: BORDER #1,1,7*9+192
1030 WINDOW #2,256,182,  0, 30: BORDER #2,1,7*9+192
1040 MODE 4
2000 :
2010 REMark  Load SuperToolkit II and/or Lightning here
2020 :
2030 base=RESPR(13480) : LBYTES drv$&'ptr_gen',base  : CALL base
2040 base=RESPR(7832)  : LBYTES drv$&'wman',base     : CALL base
2050 base=RESPR(10248) : LBYTES drv$&'hot_rext',base : CALL base
2060 :
2070 REMark  Any other resident extensions can be loaded here,
2080 REMark  including old-style HOTKEY files.  Don't put in an
2090 REMark  old BOOT_REXT with PTR in it, though unless you
2100 REMark  remove the RESPRs (etc) for PTR_GEN and WMAN!
2110 :
2120 :
2130 ERT HOT_RES('a', drv$ & 'alarm')
2140 ERT HOT_RES('c', drv$ & 'calculator')
3010 ERT HOT_RES('k', drv$ & 'calendar')
3020 ERT HOT_RES('d', drv$ & 'clock')
3030 ERT HOT_RES('m', drv$ & 'sysmon')
3040 ERT HOT_RES('w', drv$ & 'typer')
3050 ERT HOT_PICK('b','')
3060 ERT HOT_LOAD('s', drv$ & 'config')
3070 :
3080 REMark  Any other hotkeyed programs can be loaded here
4000 :
4010 HOT_GO
4020 HOT_DO 'm': PAUSE 50: HOT_DO 'b': HOT_LIST
4030 :
4040 REMark  There is now a job going, so nothing can be loaded
4050 REMark  into the Resident Procedure area.  You can still use
4060 REMark  HOT_RES, but the programs will be put in the heap.
radastan
Post by radastan »
Thanks A LOT!
This is what I need.
radastan
Post by radastan »
If I make:
Q-Emulator hangs... ¿any idea?
Probably because the space allocated in the RESPR () function is not big enough for more modern versions of PTR_GEN.
Use
WSTAT flp1_ to see the file sizes and dates etc of all files in the flp1_ directory
Or you can use
STAT flp1_ptr_gen
or just for the file length:
PRINT FLEN(\flp1_ptr_gen)
NOTE - all these commands are reliant on Toolkit II being installed.
The number passed to the RESPR () function must be at least equal to the file-length, or else you will corrupt the QL memory.
radastan
Post by radastan »
¡Yes! ¡It works! :D
I make and IMG with PE + QPAC1, very easy to use and ready to work:
http://www.bytemaniacos.com/ql/tiki-dow ... fileId=149
