UnARJ, QATS and Home Finance
I’ve just added three programs to my website. Please note that if these are not visible when you look at the page, you may need to press F5 in your browser to update the cached page:
UNARJ is an update (v.265) of the UNARJ decompressor for the QL, by Derek Stewart. Download it from http://www.dilwyn.me.uk/arch/index.html (62K download)
Home Finance – you should be able to work out what this program is from the title! It’s a former commercial title from many years ago from Buzzz Software, now available free of charge. Both 128K RAM and expanded memory versions supplied, although it's possible the expanded memory version may ironically not work too well on anything larger than Trump Card-sized memory (i.e. more than 1MB, e.g. Gold Card). Extensive Quill _doc file manuals.
Download it from
http://www.dilwyn.me.uk/business/index.html (100K download)
QATS, otherwise known as the QL Application Traffic Supervisor, is a formerly commercial program from Gordon Henson at Cope, which was made shareware. It's a utility designed to reduce the number of keystrokes needed to perform housekeeping and task control on your QL. QATS is menu driven, and the menus can be tailored to your QL setup and way of working to maximise your productivity. Includes facilities for controlling the Psion programs and other executables, swoppers and Basic programs, wildcard filename processing file and job management facilities.Works best with JS or Minerva QL ROMs, some facilities may not work on earlier ROM versions. Several Quill _doc files included, and a scanned PDF original manual also available. Download from
http://www.dilwyn.me.uk/utils/index.html (139K download)
[Please note that if these are not visible when you look at the page, you may need to press F5 in your browser to update the cached page]
