Antenna
Antenna
Does anyone know what the connectors for the two little external Wi-Fi antennae on the back of my PC's wifi card are called?
It has two normally. One still works, but after the power failure last night, the PC went down and the external antenna connector got damaged as I moved it to try to fix the PC this morning, so PC operating on one aerial out of two. I assume they're standard types (if not I'll post a photo).
Need to order replacement but don't know what to look for!
Closest I can find is RP-SMA connectors, but no idea if these are the right ones. Guess I'll need to know the operating frequency etc to get the right antenna.
TabajaraLabs
Re: Antenna
Post by TabajaraLabs »
You're right about the name of the connectors and the antenna!
