BT Phone Plug
tcat
BT Phone Plug
Post by tcat »
Dear All,
I am looking for a suitable plug to go in SER and CTL ports.
I found this on eBay, please see picture.
BT Phone Plug, right hand latch
The latch appear on the right hand side. What do you think, would it fit QL either socket, after the latch is cut off with a knife.
Many thanks in advance
TCAT
Re: BT Phone Plug
It all depends - the standard BT phone plug is too wide - however see the other thread:
http://www.theqlforum.com/viewtopic.php?f=2&t=530
You just missed out - I was selling a handful on sellmyretro which had been cut out of old systems - they were just with a lead on the end...
