Reset button
Reset button
Like the title reads, I need a reset button, including keycap. If anyone's got a spare...
Re: Reset button
I don't have any spares - there are some listed on ebay at the moment though
Re: Reset button
Yeah, they're asking for £12 (on discount) for 5 buttons stems. I need one.
And yes, I've contacted them, they won't sell one or two or anything less than 5, and the original price is £15. That makes it £5 a piece.
Right.
Right.
Re: Reset button
Update:
Does anyone else want or would be interested in reset button stems? If I posted at cost at £2 per piece?
I'd probably have 3 or 4 to spare.
- 1024MAK
Re: Reset button
Maybe...
Mark
Mark
“There are four lights!”
Re: Reset button
...depending on?
Haven't phrased it properly, though: if I *sold* them at cost, £2 per piece plus shipping at cost.
- 1024MAK
Re: Reset button
Well, you have clarified the cost.
I am not sure what part you mean. Do you mean the black button, or the switch (which is mounted to the PCB)?
Now, I have not gone looking, but they look like standard type parts (that were/are/used to be available from electronic parts suppliers), if so they are not unique to the QL.
Mark
Mark
Re: Reset button
It is the red part which goes into the reset button.....
I have about 3 left here although they are missing the springs and probably the little copper contact which comes adrift as it just sits in them....
Re: Reset button
Yes, it's the red moving part, including the black keycap, the spring and the contact.
I've looked for something similar, but I can't get the exact dimensions. Don't know if it exists, all I'm saying is, *I* can't find it.
Moreover, it's an all-plastic housing and on top of that, the button needs to be pressed in all the way, for the QL board to be taken out or put back in. That is probably what happened with the previous owner of my QL.
- 1024MAK
Re: Reset button
Ahh, I see what you mean. I would call it the plastic actuator/plunger.
Having never attempted to take one apart before (well not one of this type anyway), I did not think that it was easily removable/replaceable. On some other similar switch designs, the plastic actuator/plunger comes out the other end of the switch (if you need to remove it).
Mark
Mark
