P_ENV
EmmBee
P_ENV
Post by EmmBee »
Hi all
I have a poser. I would like to be able to distinguish whether an application has been started with either EX, EXEP file_task, U or simply RUN (from S*BASIC). The idea of all this being to take the appropriate action on whether the Window manager is active or not. I thought I could use the function P_ENV to determine this, as detailed in the SBASIC/SuperBASIC Reference Manual. This function is from the toolkit MULTI, however, this seems to be missing from the supplied disk. So, the question is: how else to do this? - or - does anyone have this toolkit?
EmmBee
