Does anyone know of any JEDEC compliant programs or utilities that can erase and programme flash in a QL? If so, would they be willing to share? I normally use socketed parts but I'm now using an SMD part on this almost finished board. I don't want to put a huge header on it and would like to program it in system in the QL using the QL
If such a thing doesn't exist, it could be the first bounty!?
For bounds, if it were a BASIC instruction it would have a way of reading the flash capabilities block using the JEDEC standard knock. With that data presented it could offer menu options to erase or write sectors. During the write cycles, multitasking needs to be disabled or the QL needs to be running off an OS image that isn't stored in the flash. In erase/program mode all cycles to the flash must be only abut programming. Other accesses elsewhere are ok, just not on the flash chip.
FLASH is taken *doh!* so I'll just give an example like so:
JEDEC_R $E00000 [read datablock of flash starting at 14MB boundary]
JEDEC_EA $E00000 [erase ALL sectors of flash at 14MB]
JEDEC_E $E00000, N [erase sector N of flash at 14MB]
JEDEC_W $E00000, N, flp1_myrom.img
[write sector N of flash starting at 14MB with the image in file given]
Anyone wishing to know more about the JEDEC standard for flash can read:
https://web.archive.org/web/20090306191 ... d68-01.pdf
