CTL plug type
actualreality
CTL plug type
Post by actualreality »
Good morning everyone.
It's been a way overdue project, but i'd like to make a conversion cable for the QL so i can use my existing Atari style 9 pin joysticks.
I bought some female 9 pin din connectors to solder the cable to, and a fully wired BT extension cable (6 pins)
I'm sure what you know what i am about to type - the BT plug doesnt fit the socket. Assume it's obviously similar, but not right what i have - can anyone point me in the right direction of the right plug?
Thanks
Regards
Darren
Re: CTL plug type
Unfortunately, these are extremely hard to find.
The correct ones were listed a short while back on sellmyretro.com - see:
http://www.sellmyretro.com/offer/details/2650
Alas, I just happened to come across those two. The Serial Ports use the BT 630W connector, but I don't know the part number for the Joystick ports.
I have one more here, but it is missing one of the tiny metal pins :(
Re: CTL plug type
The serial ports use style 630W. The joystick ports use style 630A. These are still manufactured and in use by some european companies for internal interconnects. As for where to get them :) Good luck!
Re: CTL plug type
I guess this should be the correct one:
http://uk.farnell.com/pro-signal/a136/p ... /dp/916535
"Until stocks exhausted"....
actualreality
Re: CTL plug type
Thanks for your replies!
Just found 2 packs on ebay:
http://www.ebay.co.uk/itm/BT630A-TELECO ... 5aefa14433
Will let you know how i get on.
Thanks again
regards
Darren
Re: CTL plug type
The 631 is dissimilar to the 630 because it has a different key on the back preventing it being inserted into a 630 socket.
Re: CTL plug type
tofro wrote:I guess this should be the correct one:
Those are the right hand ones (for serial ports) - the left hand ones are:
http://uk.farnell.com/pro-signal/a172/p ... /dp/916559
We will see if they are the correct ones when actualreality gets the ones they bought on ebay - if so, I might just buy the remaining stocks from Farnell (even if they are white)
Mr_Navigator
QL Fanatic
Re: CTL plug type
Post by Mr_Navigator »
Dave wrote:The 631 is dissimilar to the 630 because it has a different key on the back preventing it being inserted into a 630 socket.
I seem to remember mine being ahem! Modified with a Stanley knife
Warning - using a Stanley knife is dangerous blah blah blah don't do it without suitable supervision from an adult, medical kit and a handy phone. :lol:
actualreality
Re: CTL plug type
Hi all
Finally received the plugs - key on the correct side, but still seem too big to go in smoothly.
Might get some sandpaper on it and let you know how it goes - but at the moment it's a non-starter
(and yes I've tried with the cable on the plug fully crimped and also fully crimped with no cable :) )
regards
Darren
Re: CTL plug type
actualreality wrote:Hi all
regards
Darren
Well keep a set of pins, and you can have the connector from me which is missing at least one of the pins :)
