lhq syntax
gregtaylor
lhq syntax
Post by gregtaylor »
Doesd anyone know the syntax to use lhq to extract all files from a repository? Hav tried every option I can think of. Have determined that lhq h does not work but lhq;h does so think I need lhq;x but struggling from then on.
Greg
desin
Re: lhq syntax
Post by desin »
ex dev_lhq_exe ; 'h'
data_use 'dev' : ex dev_lhq_exe ; 'x dev_test_lzh'
hope it helps
Markus
Re: lhq syntax
you could redirect the help screen to channel in the command line, all C68 programmes accept this type or redurection.
EX lhq,#1;"h"
or use ACP and do not worry about the command options, as ghey are set in the ACP archiver options.
