PCQLTransfer
SM7I
PCQLTransfer
Post by SM7I »
Now it´s here and I´ve entered the competition with PCQLTransfer !
The transfer solution between PC and QL (TCP/IP enabled emulators so far, but soon be released also for Next QL core).
Unpack and you´ll get two zip files, PC side and QL side. Read the readme file in the PC side zip file which contain all needed information to get this running.
A clarification is needed as I read through the readme again. The fixheader Superbasic program is only needed to be used if you transfer binaries directly from PC to QL. It´s *not* needed if you transfer zip files as they already retain the magic field of binaries inside the zip file.
Download is available from below link at Specnext. Please vote for me and PCQLTransfer if you like it ! Thanks !
https://www.specnext.com/white-next-con ... hfOEvC_Pyw
Re: PCQLTransfer
I use a QL, Q68, QXL, conneted to the QL Network, connected to a PC via QLUB, with QPC2, SMSQmulator, sQLux, UQLX, Qemulator acting as a server to the native file system, by a predefined device.
I transfer files from SMSmulator NFA1 drive mapped to the PC home directory to the Q68 WIN1 drive on the SD Card or any other QL node on the QL Network.
I have not built the Next QL core Network adaptor yet, but this should link into thd QL network, via QLUB.
