PCQLTransfer
SM7I
PCQLTransfer
Post by SM7I »
Now it´s here and I´ve entered the competition with PCQLTransfer !
The transfer solution between PC and QL (TCP/IP enabled emulators so far, but soon be released also for Next QL core).
Unpack and you´ll get two zip files, PC side and QL side. Read the readme file in the PC side zip file which contain all needed information to get this running.
A clarification is needed as I read through the readme again. The fixheader Superbasic program is only needed to be used if you transfer binaries directly from PC to QL. It´s *not* needed if you transfer zip files as they already retain the magic field of binaries inside the zip file.
Download is available from below link at Specnext. Please vote for me and PCQLTransfer if you like it ! Thanks !
https://www.specnext.com/white-next-con ... hfOEvC_Pyw
Re: PCQLTransfer
In case it was not known: There is also the TFTP file exchange program from Wolfgang, which supports both emulators and native machines like the Q68.
http://www.wlenerz.com/qlstuff/
It handles the XTcc trailer transparently and thanks to the standard protocol runs across platforms, not just Linux.
