Linux QL RS232 cable wiring
tcat
Post by tcat »
Dear All,
Would anyone help with an RS232 cable wiring between Linux and QL?
Linux standard tty terminal driver does not use DTR / DSR
signals, only RTS / CTS lines for handshaking
So to connect a QL with a Linux system, I was thinking of this cable wiring, but not sure.
QL <==> Linux
TX <==> RX
RX <==> TX
CTS <==> RTS
DTR <==> CTS
OV <==> 0V
9V <==> 9V
On the same analogy, could I also connect a ZX Spectrum's Interface1 with the same cable?
My idea is to exchange data between QL or ZX and Linux, by typing on the command line, e.g.
# setting up baud rate, h/w handshake, stop bits, etc
$ stty -F /dev/ttyS1 19200 cs8 clocal cstopb raw crtscts
# sending data down
$ cat file.in > /dev/ttyS1
# receiving data up
$ cat /dev/ttyS1 > file.out
Many thanks in advance
ppe
Re: Linux QL RS232 cable wiring
Post by ppe »
you can find useful information on the serial port on Dilwyn's wonderful QL pages:
http://www.dilwyn.me.uk/docs/hardware/index.html The file "serials.txt" inside downloadable "serials.zip" should have all the information you need.
Petri
Mr_Navigator
QL Fanatic
Post by Mr_Navigator »
I wrote an article for QL User many years ago for that very purpose, the article contained the necessary connections for Interface 1 and the QL, I will try and dig it out if you still need the information.
Mr_Navigator wrote:I wrote an article for QL User many years ago for that very purpose, the article contained the necessary connections for Interface 1 and the QL, I will try and dig it out if you still need the information.
To save Mr Navigator some time, being as he's busy making Quanta magazines, and as I happened to have that particular issue to hand...
*cough-splutter*
I remember that article! I am at the feet of greatness!
Mr_Navigator
QL Fanatic
QL User phoned me on a Friday asking for the article based around what I sent them which was the program, the lead and the briefest of instructions, they wanted it sent out in the post on the following Monday. Typing this all up on the Saturday I was very excited about the prospect. Written in Quill, I made my final changes on Sunday morning, and went to save as normal. As instructed by most programs of the time, save regularly, which I did. On this occasion however during the save my AH ROM QL locked up and I lost everything. :cry: The article had to be rewritten, but it wasn't the same and no time to do proper proof-reading. Since then and even now my save routines are always double saves so that in the event of a lock-up I can at least recover something.
JonB
Post by JonB »
So.. how do you set up the baud rate and handshake on the QL?
I've got mine connected to a Mac via a serial adapter, and so far nothing from SER2. Plugging it into SER1 gives gibberish with noting actually being sent.
I need a simple bit of SBasic to test the link is correct..
Mr_Navigator
QL Fanatic
Baud rate is fairly straight forward using the BAUD command followed by the rate see online user guide below.
http://www.dilwyn.me.uk/docs/ebooks/olq ... s.htm#baud
Never got involved with handshaking, just used the wiring as per spec.
dex
Post by dex »
I have bought converting cables for the UK QL here: http://www.thesinclairshop.com/
Although nice looking (and a big bit expensive), they have one disadvantage: they don't work on the QL (I didn't test them with ZX Spectrum 128+, which has the same serial connector).
The solution is to disassembly the PC side connector (Canon 9) of the cable, and to resolder (red) wire from pin 4 to pin 7.
Serial communication works then perfectly (tested using Mac connected via USB-serial convertor to SER1; I didn't test it with SER2 yet).
Mr_Navigator
QL Fanatic
Very colourful the Sinclair Shop
