SOLVED !! minerva and a gold card ??
techy
Post by techy »
Will minerva wotk together with the original gold card ?
Re: minerva and a gold card ??
techy wrote: Sun Mar 30, 2025 6:00 pm Will minerva wotk together with the original gold card ?
Yes! My QL is Minerva + original SGC + QL-SD
techy
Post by techy »
thank you !!
Yes, Minerva will run just fine on a Gold Card - Although you might prefer to run SMSQ/E on it, as it is just so much better.
techy
Re: SOLVED !! minerva and a gold card ??
Post by techy »
Thank you all for your replies .
techy
Post by techy »
