QLCommander v2.2.7 - Release
This is the final release of QL Commander v2.2.7
The zip file includes all QLC files + Source code + a pdf Manual
qlc.zip
(3.08 MiB) Downloaded 114 times
javier2112
Re: QLCommander v2.2.7 - Release
Post by javier2112 »
Andrei, did you change anything respect the last beta?
I just I copied all files and replaced qlc227m5_exe to qlc227_exe in my loader. Now I get the following error:
LGET is not LOADED
javier2112 wrote: Fri Mar 21, 2025 1:43 pm Andrei, did you change anything respect the last beta?
LGET is not LOADED
I changed a lot since last beta - added a lot of error trapping and a few other smaller changes :)
And it seems that I tested twice on SMSQE instead on SMSQE and Minerva. My fault!
Now I fixed it! And tested in Minerva
Please download again the archive from first post!
javier2112
Thanks Andrei. Now works fine :)
7alken
Post by 7alken »
hi Andrei, congrats to new great release! - I only this week jumped back into QLC to test and unify my "LSBGEN" (LSB finally as some "lightweight" SSB, as it was started during analysis of QLC code which I converted into it) both on QPC2/SMSQe and registered Qemulator/minerva ... I will test and try to adapt everything, although I am using it in source form on full-speed emulators, mostly.
I got finally also ram and minerva and soon hope also micropicodrive for my UK BBQL, so more fun :-)
Goal is to integrate LSB into modified QLC (qlxc or just xc) as natural way of fast coding.
I use LSB as prototyping language for some new embedded things.
Just today got also idea of "ED" replacement by syntax coloring for LSB (and beyond).
Your great QLC is THE thing why I am so interested in QL and SB.
cheers to all
Petr
Popopo
Post by Popopo »
Nice work Andrew!
Thank you very much.
