Python program to pad ROMs to exactly 48 K (e.g. for sQLux)
UQLX can use ROMs which are less than 49152 Bytes (48 K), but sQLux complains. So I have written a quick and dirty Python program to make a 48 K ROM from those ROMs. Hint: The program does not allow to overwrite the existing ROM on disk, you must save it with another name.
- padRomTo49152.zip
- (827 Bytes) Downloaded 12 times
Re: Python program to pad ROMs to exactly 48 K (e.g. for sQLux)
The next release of sqlux will likely accept ROMs shorter than 49152 Bytes.
I'm not sure, if this is a good idea. A ROM should have exactly 49152 bytes. With the current version of sQLux it is much more difficult, to load a file, which is no QL-ROM. It would only make sense, if ROMs >48K can be loaded as system ROM, and even than, it would be nice, if sQLux checks, that it is e.g 64, 128, ... KBytes exactly.
- XorA
- Site Admin
truncate -s 48k test.rom
Much easier than python
Well, we need to accept what's out there. And there's plenty of ROMs floating about shorter than 49152 bytes. If we supply a warning if a "short ROM" is detected, that should be enough.ql_freak wrote: Mon Mar 10, 2025 12:42 am I'm not sure, if this is a good idea. A ROM should have exactly 49152 bytes. With the current version of sQLux it is much more difficult, to load a file, which is no QL-ROM. It would only make sense, if ROMs >48K can be loaded as system ROM, and even than, it would be nice, if sQLux checks, that it is e.g 64, 128, ... KBytes exactly.
- XorA
- Site Admin
I accepted tofro's reasoning and sQLay3 already did except short roms, so I merged his patch a few minutes ago!tofro wrote: Mon Mar 10, 2025 12:08 pmWell, we need to accept what's out there. And there's plenty of ROMs floating about shorter than 49152 bytes. If we supply a warning if a "short ROM" is detected, that should be enough.ql_freak wrote: Mon Mar 10, 2025 12:42 am I'm not sure, if this is a good idea. A ROM should have exactly 49152 bytes. With the current version of sQLux it is much more difficult, to load a file, which is no QL-ROM. It would only make sense, if ROMs >48K can be loaded as system ROM, and even than, it would be nice, if sQLux checks, that it is e.g 64, 128, ... KBytes exactly.
