New Q60 Boards
Locked
New Q60 Boards
I am wondering if there is a demand for more Q60 boards, which D&D System used to sell.
Except, I would only want to produce a Q60 with 80Mhz 680LC60 with MMU, but without a FPU.
There is a problem with the VGA output when in 1024x512 Mode 33 not working correctly on modern TFT monitors.
I used to use a 17" CRT SVGA monitor, but these monitors are very expensive or not available.
The OSSC video converter could be used to convert the video signal on the Q60. But the OSSC is very expensive, but is open source, maybe the hardware could be customised for the Q60.
Just thoughts here...
I will look into production of Q60 later this year as I have some Q68 to build.
Re: New Q60 Boards
I might be interested Derek - but just wondering if the video issue might be resolved by having the video fed through a Belkin KVM switch? It seems to deal with a wide range of video input signals from various 'VGA' devices, is there any way of testing that video frequency / sync rate against it? - by which I meant it's possible to alter the video output of a Raspberry Pi to produce all sorts of standard and not so standard frequencies, and if I could emulate the same with an RPI, I could test if it would work with my setup.
I'd need some details of the video front porch / backporch timings, sync polarity, video frequencies and sync frequencies.
napsternds
Re: New Q60 Boards
Post by napsternds »
Hi Derek,
I would be definitely interested. Any idea about price range?
Thank you
Re: New Q60 Boards
Pr0f wrote: Thu Jan 23, 2025 4:42 pm I might be interested Derek - but just wondering if the video issue might be resolved by having the video fed through a Belkin KVM switch? It seems to deal with a wide range of video input signals from various 'VGA' devices, is there any way of testing that video frequency / sync rate against it? - by which I meant it's possible to alter the video output of a Raspberry Pi to produce all sorts of standard and not so standard frequencies, and if I could emulate the same with an RPI, I could test if it would work with my setup.
I will look out my notes, I did measurd the Q60 Video output.
What model of Belkin KBM switch?
Re: New Q60 Boards
napsternds wrote: Thu Jan 23, 2025 9:16 pm Hi Derek,
Thank you
I have not looked at the part prices, yet.
Re: New Q60 Boards
Derek_Stewart wrote: Thu Jan 23, 2025 10:25 pm
I will look out my notes, I did measurd tgd Q60 Video output.
I have the Belkin Omniview Pro3
Re: New Q60 Boards
Derek_Stewart wrote: Thu Jan 23, 2025 3:53 pm I will look into production of Q60 later this year as I have some Q68 to build.
I could use another Qx0 mainboard, even without CPU, even if I have to repair, but within the next few weeks.
If you have something for me, please email.
Re: New Q60 Boards
Derek_Stewart wrote: Thu Jan 23, 2025 3:53 pm There is a problem with the VGA output when in 1024x512 Mode 33 not working correctly on modern TFT monitors.
I can offer an alternative video logic which produces 1024x768, but with black bar in the bottom.
Re: New Q60 Boards
Hi Peter
I may already have a LCD Chip.
Asmention above I have some Q60 boards, but I do not like selling anything that doesn't work. I am not Qbranch which was his practice to sell everything whether it worked or not.
The point of this thread, was to see if there was any interest in a POSSIBLE remake of the Q60.
Which this will be done after June.
ql_freak
Re: New Q60 Boards
Post by ql_freak »
1) What is a Q60 Board?
2) What is needed, that it can be used (except Monitor, keyboard, power supply)?
If it can run QDOS (e.g. Minerva) or SMSQ/E I would be definitely interested. Depending on the price I would eventually order two.
Locked
