MDVRAW tape format
M68008
MDVRAW tape format
Post by M68008 »
As mentioned in another thread, current file formats for microdrive images seem to be limited to 512-byte sectors and don't support GST/68K microdrives.
I wanted to develop a lower level representation of the tape that can be used by any QL OS and doesn't require knowing what format that OS uses.
Ideally, I would do more research and tests, but time is limited and I don't have all the hardware needed, so I decided to just release what I have. Please feel free to comment!
This is not meant to replace existing formats (it's harder to use), just to enable GST/68K to use microdrive tapes in software emulators and enable playing with non-standard formats in general. It should also be relatively easy to support by hardware emulators if desired as they would just have to play back the byte stream with no special logic related to block structure.
I have collected a few images from physical QDOS, GST/68K (collected by Tony) and OPD cartridges. I have not found a Spectrum cartridge to try, yet.
Physical dump is currently based on attaching a logic analyzer (there are inexpensive ones) to the microdrive port and recording a few loops of the tape. A microdrive cable or other connector is helpful to attach the probe.
A utility (written in C++) converts the signal to MDVRAW.
Not sure whether a QL could collect similar traces in software or not, one of the problems is that the ZX8302 sometimes seems to give up when it encounters errors. It also imposes its own timing, while a utility that interprets the logic trace can be more flexible and hopefully recover tapes that have been stretched or have misaligned tracks or other intermittent errors.
The tape representation is byte-based and for each byte there is an extra bit (in a separate area of the file) to tell whether that byte is actual signal or a 'gap' (= no magnetic transitions). This simplifies access to the tape and makes the images shorter (about 200 KB) compared to using individual bits or raw magnetic transitions ('flux'), but is still harder to use from software compared to block based formats.
The ZX8302 constrains the input to be a stream of bytes at a bit frequency of 100 Kb/sec. The tape has two tracks, at an offset of 4 bits and with bytes alternating between the two tracks, but this file format hides that and just provides a single byte stream.
QL software could still start writing in the middle of an existing byte and this seems to result in OPD tapes having a half-byte of space between the block header and sector header, but I think rounding to the next byte should be good enough.
Writing to microdrives is done entirely in software on the QL, but reading from them is a combination of hardware and software. The ZX8302 is tasked with recognizing the starting 'preamble' of each chunk of valid data on the tape. There is also a gap interrupt as an optimization (to know when a sector is about to start without having to continuously monitor the input stream) and a other hardware registers that are also used by the software.
Unfortunately, this way of reading and writing results in an ambiguous representation on the tape: The same sequence of bytes in a preamble (at least 6 bytes of zeros followed by FF FF) could be present inside the sector data and the only way to tell them apart is the timing of read operations in the OS.
Q-emuLator will probably take this approach and just let the QL OS deal with the file format, while providing precise tape and CPU timings.
Other tools or emulators that just want to access sectors from the image can use heuristics to find all preambles in the byte stream. Most preambles are not far from the last gap. Others need an assumption about what QL OS wrote to the tape. There is a field for the OS type in the header, but it might not always be accurate. It should also be possible to infer the OS from the sizes of data chunks.
I plan to write and release some C code that identifies sector locations inside the MDVRAW.
Here is the current proposed header definition:
struct Header
    char        id[8];                  // "QLMDVRAW"
    uint16_t    headerSize;
    uint16_t    fileFormatMajorVersion;
    uint16_t    fileFormatMinorVersion;
    uint16_t    creatorId;              // 1 = MdvDecode
    uint16_t    creatorMajorVersion;
    uint16_t    creatorMinorVersion;
    uint16_t    creatorRevision;
    uint8_t     ulaFamily;              // 0 = Unknown, 1 = ZX8302, 2 = Interface 1
    uint8_t     recognizedFileSystem;   // 0 = Unknown, 1 = QDOS, 2 = Spectrum, 3 = OPD, 4 = GST/OK
    uint32_t    frequency;
    uint32_t    dataOffset;
    uint32_t    dataLength;
    uint32_t    gapBitmapOffset;
    uint32_t    gapBitmapLength;
    uint32_t    junctionStartOffset;    // Optional unreliable section of the tape
    uint32_t    junctionLength;
    uint32_t    extensionOffset;        // Future format extension
    uint32_t    recommendedInitialTapePosition; // Optional initial position to quickly get to sector zero
    uint32_t    currentTapePosition;    // Optional, if we want to restart the tape from the last used position
The important fields are:
    char        id[8];
Using the other fields is optional.
The gap bitmap area has one bit for each byte in the data area. 0 means gap and 1 means valid signal.
All offsets are from the start of the file and I'm leaning toward using little-endian byte ordering to simplify all tools.
Thanks,
Daniele
Re: MDVRAW tape format
Hi Daniele,
I’ve just managed to get all the necessary hardware setup to try and capture the gst asm for 68k/os, so will give it another go sometime today and email to you?
If you’d like I can re-felt a zx spectrum md and capture that as well, but I’ve no way at the moment to test if the md is good or not. Let me know if you’d like me to try the capture anyway
Just got to track down the instructions to do the capture(s) in the forum
Thanks
Tony
I've captured 2 different MD's of GST ASM MD & a ZX Spectrum Games MD
No idea if the captures are good or not, but please let me know if you'd like them sent over
Tony
