Aurora and GoldCard (not Super Goldcard): Resolution, Colours
ql_freak
Post by ql_freak »
I only have an orginal GoldCard (NO Super GoldCard).
Can I use Aurora with it, and if yes, what is the maximum resolution and colour depth?
BTW: Will anyone sell a Super GoldCard ;-)
Re: Aurora and GoldCard (not Super Goldcard): Resolution, Colours
Aurora will work with a (non super) Gold Card, but will not have access to the higher video mode resolutions. This is because in the SuperGold Card A18/A19 (they are tied together) can be used to place the Aurora video RAM at a higher address outside the 4MB of the SuperGold Card, on the Gold Card, these lines are just tied to ground, so there is no (easy) way to access the extra video memory. To get access would require modification of the Ingot chip and edge connector, but is theoretically possible.
ql_freak wrote: Thu Dec 19, 2024 1:05 am I only have an orginal GoldCard (NO Super GoldCard).
From what I read, it should work with the yellow GoldCard (not the red one).
You will not be able to use the higher resolutions of the Aurora with a GoldCard only, because its external address bus is limited (The Gold Card will simply not be able to reach into the extended screen memory). So, it is a bit pointless with a GC only.
ql_freak
Post by ql_freak »
Thank You!
Nasta
Post by Nasta »
It should work with any GC save for the early yellow ones if they were not patched, but you are only limited to standard QL resolutions, albeit on a VGA monitor. GC does not address anything on the bus except the ROM (while initializing), IO and the first 64k of motherboard RAM and the latter only for writes. Since the extra screen RAM needed for higher resolutins and more color is located in address areas the GC does not access, it can only use original QL resolutions.
It might be an option to simply make a replacement GC/SGC board and transfer the chips across from a donor to separate A18/A19? Such a board would likely be quite cheap to assemble as it's just passives, sockets and an LDO.
Nasta
Post by Nasta »
Dave wrote: Thu Jul 17, 2025 10:20 pm It might be an option to simply make a replacement GC/SGC board and transfer the chips across from a donor to separate A18/A19? Such a board would likely be quite cheap to assemble as it's just passives, sockets and an LDO.
I think the problem with the old yellow GCs was that A18 and A19 were left floating since they are not used on the QL motherboard. If I remember right, the patch consisted of bridging A18 and A19 on the GC and adding a 1k resistor from there to GND to pull A18 and A19 low.
