microp QLFDV V5.1
thecaver99
microp QLFDV V5.1
Post by thecaver99 »
im not sure if this would go into hardware or software sections as its the utilities disk for the hardware.
would anyone have the utilities floppy for the QLFP interface, the only reference i can find is https://qlwiki.theqlforum.com/doku.php?i ... _interface,
and yet the image is no longer, they are calling the file microp_utility_disk.
cheers
Re: microp QLFDV V5.1
thecaver99 wrote: Fri Oct 18, 2024 8:28 pm im not sure if this would go into hardware or software sections as its the utilities disk for the hardware.
cheers
I think what you are looking for is on this page https://dilwyn.theqlforum.com/docs/manua ... _Interface
thecaver99
t0nyt wrote: Fri Oct 18, 2024 8:46 pm
cheers
Now why couldn't I find that even searching to micro peripherals,.
I have been searching all last night and today.
Thank you I will have a look at that tomorrow.
If you tried using the site search box on my site, it only updates its info periodically (free version after all). If I update something major I have to remember to log into it and tell it to rebuild its info. Probably forgot to do it with that update, maybe? Could also use google site: search if you can't find something on my site that you know is meant to be there.
Regarding the MP interface utilities, bear in mind that some MP interfaces have been updated with Tony Tebby's QFLP eprom. I don't know if the utilities disc would work with that, or just with the original MP eprom.
