QL PASCAL v1.8
QL PASCAL v1.8
I've just been going thru testing my various ROM dongles and I have one with no label
I dumped the contents and at the start of the ROM it says "QL PASCAL Version 1.8"
I was wondering if anyone knew which PASCAL this actually is please?
Re: QL PASCAL v1.8
It's Metacomco Pascalt0nyt wrote: Tue Oct 08, 2024 11:43 am I dumped the contents and at the start of the ROM it says "QL PASCAL Version 1.8"
Re: QL PASCAL v1.8
Many thanks Andrew
(By pure co-incidence I have original MDV's for that on the way to me to go with it)
Re: QL PASCAL v1.8
I think the ROM isn't original as I've just opened it up and found the circuit board is stamped "Care"
Re: QL PASCAL v1.8
That is OK. Care Electronics was, to my knowledge, the only producer of these ROM dongles and all the software houses (QJump as well) used their dongles.t0nyt wrote: Tue Oct 08, 2024 1:44 pm I think the ROM isn't original as I've just opened it up and found the circuit board is stamped "Care"
Re: QL PASCAL v1.8
That’s good to know, many thanks tofrotofro wrote: Tue Oct 08, 2024 2:09 pmThat is OK. Care Electronics was, to my knowledge, the only producer of these ROM dongles and all the software houses (QJump as well) used their dongles.t0nyt wrote: Tue Oct 08, 2024 1:44 pm I think the ROM isn't original as I've just opened it up and found the circuit board is stamped "Care"
Re: QL PASCAL v1.8
Well the original Metacomco Pascal MDV's arrived and they are v1.4 (my existing dongle is v1.8) and I was able to MDUMP them to mdv images
Fortunately the MDV's also came with a v1.4 ROM image
But when I load the v1.4 ROM image in Q-emuLator and try to run Pascal it complains the ROM isn't present or is the wrong version
I've not yet tried burning the ROM to an eprom to test on a real QL as yet though
But I was wondering if anyone has any other thoughts please?
Re: QL PASCAL v1.8
Prospero Pascal is on the QL Homepage, which the rom image v1.15 is included.
I loaded this into Q-emulator, which recognised the ROM in startup, and entering PRL loads the rom.
Have copied the ROM correctly?
Re: QL PASCAL v1.8
How do you load the ROM?t0nyt wrote: Wed Oct 16, 2024 6:28 pm But when I load the v1.4 ROM image in Q-emuLator and try to run Pascal it complains the ROM isn't present or is the wrong version
In QEmulator -> QL Configuration you must load the Metacomco ROM as "Back ROM" and set it to "Active"
I tested with v1.8 - there is no message that the ROM is loaded, but programs ED (editor) and Pascal (compiler) work.
Re: QL PASCAL v1.8
I don’t have PRL?Derek_Stewart wrote: Wed Oct 16, 2024 6:51 pm Hi,
Prospero Pascal is on tge QL Homepage, which the rom image v1.15 is included.
