Is this a real MDV or something made up?
Does anyone recognise this Games MDV please?
Is it just something someone's made maybe? Seems to be the menu from the usual Games Cartridge
The Frogger has this splash screen
Screenshot 2024-10-05 at 16.42.11.png (10.95 KiB) Viewed 3229 times
Re: Is this a real MDV or something made up?
Does it have any dates associated with it? If it's 80s/90s I'd say that the Frogger splash screen points to it not being a homebrew. The selection screen is primitive, but so was Psion's one for each of their apps.
bwinkel67 wrote: Sat Oct 05, 2024 7:42 pm Does it have any dates associated with it? If it's 80s/90s I'd say that the Frogger splash screen points to it not being a homebrew. The selection screen is primitive, but so was Psion's one for each of their apps.
I couldn't find anything to date it but the menu code is identical to the official QL Games cartridge menu code
Also, the official games cartridge has 5 entries and this one lets you select the 5th entry even though it doesn't exist
I think the conclusion can only be that someone made the cartridge
BTW Blue Meanies looks a fun little game though I've not worked out how to move left/right yet (using a keyboard). Froggy crashes Q-emuLator when frog gets killed. Mastermind is just a very basic text game. Othello runs but not tried a game yet.
I think that Frogger was a type-in from QL World.
The code says : COPYRIGHT A.S.DAY 1985
The program was available from QL World and Quanta and also from TF Services’ Bulletin Board.
The boot file has some REMarks:
90  REM will only work with unexpanded QL
95  REM If any hacker finds a way to get 'normal'
96  REM vehicles with expansion board (reset to 128K)
97  REM plse let TOny Firshman know (01-724 9053)
Andrew wrote: Sun Oct 06, 2024 11:41 am I think that Frogger was a type-in from QL World.
Thanks, yes that’s the same one
I think Blue Meanies may of been a type in as well (so probably the others too)
Have found the magazine listing for Blue Meanies (Your Computer Oct 1985)
So now have the instructions to give it a proper go sometime
t0nyt wrote: Sun Oct 06, 2024 12:09 pm I think Blue Meanies may of been a type in as well (so probably the others too)
Blue Meanies is a type-in from Your Computer issue v.5 #10 - October 1985
Froggy is a type-in from QL User issues December 1985 and January/February 1986
Was the splash screen for Frogger part of the type in? If so, that's some pretty fancy BASIC. Curious how that was done.
bwinkel67 wrote: Sun Oct 06, 2024 5:48 pm Was the splash screen for Frogger part of the type in? If so, that's some pretty fancy BASIC. Curious how that was done.
It was a machine code type in
No, it was not.
