Guess what I'm making :)
I ordered the following today. Can anyone guess what I'm making?
110	P1.00KFCT-ND	 RES 1.00K OHM 1/4W 1% 1206 SMD	  0	0.028	 $ 3.08
165	399-3676-1-ND	CAPACITOR TANT .10UF 35V 10% SMD	0	0.1645	$27.14
220	493-1036-ND	  CAP 10UF 16V ELECT VR RADIAL		 0	0.0884	$19.45
55	 NJU7660M-ND	  IC DC/DC VOLTAGE CONVERTER 8-DMP	0	0.95	  $52.54
110	478-1903-ND	  CAP TANT 4.7UF 10V 10% RADIAL		0	0.3168	$34.85
55	 WM9132-ND	    CONN HEADER 4POS .200 VERT		   0	0.6578	$36.18
400 ft magnet wire, 38 gauge
Here's a clue: built by TF Services, really useful to have :)
Re: Guess what I'm making :)
Now if it were only a ROMDisq - but looks more like a Minerva - MKII if lucky !!
I was thinking more along the lines of Mechagodzilla?
vanpeebles wrote:I was thinking more along the lines of Mechagodzilla?
if that 400ft of magnetwire is anything to go by ... :P
Or if Tony's son Ben was anything to go by, Legodzilla :idea:
Nobody's even close yet :)
Mr_Navigator
QL Fanatic
Post by Mr_Navigator »
A battery/generator
QL power supplies for Rich or Mplanes
MPlanes for the win!
I am completing the remaining stock of MPlane PCBs and Minerva PCBs.
Dave wrote:MPlanes for the win!
So where does the 400 ft magnet wire, 38 gauge come in?
The Mplane was designed for Auroras and Gold Cards... It therefore omitted a track which is needed if you use an original QL board. Tony used to place this missing track by hiding the wire under the connectors, and I will be doing the same. Magnet wire is perfect - it comes with an insulating coating that protects against shorts, but that works as a flux when soldered.
