Some possibly silly ideas?
Wicksy
Post by Wicksy »
As I've been looking around for bits for a future Q68 and maybe QL, I came upon some items that may work or not?
For a Q68, a USB keyboard via ethernet adapter which sends UDP. I've not a clue how this could work or what drivers would need to be written?
https://www.keelog.com/keyboard-ethernet/
For a Ql, this may partially work if at all for cursor use through CTL! for editing or games? If not, the serial ports via a program routine? Again am not sure of the plug orientation, but it looks like SER1/2 spec? I know this reproductions firmware is written to work on the 128, but could it work?
https://retroradionics.com/ZX-Spectrum- ... p135657482
Re: Some possibly silly ideas?
Wicksy wrote: Tue Apr 09, 2024 4:55 am For a Q68, a USB keyboard via ethernet adapter which sends UDP. I've not a clue how this could work or what drivers would need to be written?
If you really need to use a pure USB keyboard (for a wired keyboard you probably don't) it is better to use an active USB-PS/2 adaptor.
Wicksy
Post by Wicksy »
Thanks Peter
