Q-Liberator 3.46
Q-Liberator 3.46
Version 3.46 of the Q-Liberator compiler is now available to download from https://dilwyn.theqlforum.com/qlib/index.html
The source files are also available on the page.
Re: Q-Liberator 3.46
Thank you Dilwyn!
Please check the link for Qlib346u.img.zip - it points to Qlib345u.img.zip
Andrew wrote: Wed Mar 20, 2024 10:55 pm Thank you Dilwyn!
I'll change it - interestingly the link has somehow split on half, hover over the left of the link you get 3.45 and towards the right you get 3.46. Wonder how I managed that? Maybe the two periods in the filename confused my html editor.
I downloaded the zip file and unstalled it onto a QLWA file for SMSQmulator, QPC2, Q68, QL + Trump Card 2, QIMSI, QLSD.
All works great, Qliberator is one the bext QL software available.
Thank you for the upgrade to this excellent compiler system and making it freely available.
When I lrun flp1_boot on Q-emuLator, with nothing else loaded, it crashes out (see image)
But if I boot Q-emuLator with the img already in the flp1 device slot it loads fine
Is there any obvious reason for this please?
Just tried on real iron and the same thing happens
I downloaded qlib345u.img into Q-emulator, mapped to to Slot 1, booted up OK not errors, loaded the compiler front end no problems.
I am using Minerva v1.97, Toolkit 2 in q-emulator.
Hi Derek,
If you boot up and then attach the image and then lrun flp1_boot does it load please?
If I boot with the image already in the slot it works ok, but not if I boot and then lrun flp1_boot
I downloaded: https://dilwyn.theqlforum.com/qlib/Qlib346u.img.zip
Looking at the boot file, you need Toolkit 2 installed.
Without Toolkit 2, you will have to respr the code and call it.
Derek_Stewart wrote: Mon Mar 25, 2024 10:59 am Hi,
Sorry, I should have clarified, I do always have TK2 loaded
Many Thanks
