Qcal
NL_QL_Usr
Qcal
Post by NL_QL_Usr »
In 1985-86 I recall making a calendar..
Which i liked a lot.
So here it is. It is problably different but has the same looks as i recall it.
It is a shame that i lost all my files from back then..
The program uses: win2_data_Qcal.cal
If you need to change this: look in def proc INI = calfile$
First time use: it makes a win2_data_qcal_cal file
(There is even an importent date in 1984 added!!)
arrow l r up dwn date
<shift> arrow up dwn month
<ctrl><shift> up dwn year
<space> edit an appointment
Have fun....
see updates
NL_QL_Usr
Re: Qcal
Post by NL_QL_Usr »
Upd Qcal102
At least now you can set an appointment when the ql is 50 years!! :D
<ctrl><shift> arrow l or r = updwn year
see update
NL_QL_Usr
Re: Qcal
Post by NL_QL_Usr »
upd Qcal103
Cleared a lot off mistakes and hopefully didnt make to many new.
Added: F3 commands
<b>ackup makes an win2_data_qcal_bu file
it cleans up the empty lines etc
so after the file is created
you could rename tho win2_data_qcal_cal to qcal_old
and rename de qcal_bu to qcal_cal again
the file wil be a lot cleaner
<i>mport import an _ics file
it doesnt work compiled (yet) but in superbasic it works ok
<s>earch search from main it works also with <ctrl><f>
It is at least working a lot better now grins
There is an qcal.hlp file please copy it to win1_tmp_qcal_hlp
qcal103.zip
(4.52 KiB) Downloaded 63 times
NL_QL_Usr
Re: Qcal
Post by NL_QL_Usr »
small update 104
a new appointment is saved right away.
some small changes
QCAL104.ZIP
(11.98 KiB) Downloaded 63 times
QCAL104_BAS.zip
(4.31 KiB) Downloaded 85 times
