File modified date/time
Following on from a previous post it does appear, reading online, that on floppy disks each file does have a “modified date/time” stored
Is there any Dir equivalent command or utility that displays this please?
BSJR
Re: File modified date/time
Post by BSJR »
t0nyt wrote: Fri Feb 16, 2024 10:42 am Following on from a previous post it does appear, reading online, that on floppy disks each file does have a “modified date/time” stored
Toolkit 2 has two functions to do just that. FUPDT(), FBKDT() will read the update and backup dates.
FVERS() will get the version number. This increases from 1 each time the file is saved under the same name.
BSJR
BSJR wrote: Fri Feb 16, 2024 11:00 am
BSJR
Many thanks!
Hi tonyt
Just to add that TK2 also has the 'WSTAT' command that acts like DIR but adds datestamp and filesize to the usual directory listing.
And the C68 package contains a "touch" utility that sets the update time of a file to "now".
Thanks all, that will all help a lot
Now I want a RTC more than ever!
DJToolkit has functions to read and set those dates in the file header.
WinBack used them back in the day to determine if a file needed backing up or not. Also backs up floppies and such like, not just hard discs.
Both available from Dilwyn's web page, linked as QL Homepage at the top of every forum page.
The only RTC I had was on Gold Card, Super Gold Card, Minerva MKII, QIMI.
Could a battery be attached to the 8302 to backup the date, as shown in this QIMI diagram:
This could be reproduced.
