Ql PPC Emulator
cybervet
Ql PPC Emulator
Post by cybervet »
Hi is there a QL emulator that can be used in a Mac PowerPC G5?
Thanks in advance
Tassos
Re: Ql PPC Emulator
Tassos,
Daniele Terdina still supplies an older version of his QEmulator for MacOS that can be run on PPC Macs (using the 68k emulation).
See
http://www.terdina.net/ql/MacQL.html
(Watch the small print to find the PPC version)
cybervet
Re: Ql PPC Emulator
Post by cybervet »
Hi Tobias, unfortunately my G5 runs on Leopard 10.5 which did not support the Classic environment so the 68K emulator is a no go for me any other suggestions?
Thanks
Tassos
Re: Ql PPC Emulator
Tassos,
someone (can't recall the name, but seem to remember he was french, or french-canadian?) did a port of uqlx for Darwin. Not sure if that was ever complete, ran, or even compiled, but it might be worth a search.
You might want to have a look into this
http://www.mail-archive.com/ql-develope ... 00525.html
thread.
No guarantees, though.
Re: Ql PPC Emulator
cybervet wrote:Hi Tobias, unfortunately my G5 runs on Leopard 10.5 which did not support the Classic environment so the 68K emulator is a no go for me any other suggestions?
Thanks
Tassos
QemuLator Lite existed in versions for 68k and PowerPC macs.
There was also a port of uQLx to Mac by James Weatherley which at one time was on Phoebus Dokos's website. I think it was the same as the Mac uQLx on my emulators page.
http://www.dilwyn.me.uk/emu/index.html
If the Mac concerned is able to use Java 6 or 7, try also the new SMSQmulator from Wolfgang Lenerz
http://www.wlenerz.com/SMSQmulator
