This update is a bug fix for a problem when saving a SBASIC program with NETO from QPC2 to the Q68, when Windows chops up the QL network packets.
I found this bug while working on the IP Network driver update.
There is no manual update needed.
QoE Ethernet driver version 0.44 for the Q68
- QoENET044.zip
- (370.92 KiB) Downloaded 170 times
Re: QoE Ethernet driver version 0.44 for the Q68
Here is an update for Q68 Ethernet driver, It brings it up to Version 0.45
Fixes problems in End Of File handling in IO_FBYTE, and IO_FSTRG on IP channels.
- QoENet045.zip
- (400.31 KiB) Downloaded 101 times
