Archive pdf
NL_QL_Usr
Archive pdf
Post by NL_QL_Usr »
Was having fun fooling around with Psion Archive.
I couldn't find an archive Manuel.
So I scanned my own.
May by of some help for someone....
archive.zip
(14.08 MiB) Downloaded 164 times
swensont
Re: Archive pdf
Post by swensont »
I did my own version too:
http://swensont.epizy.com/Archive.pdf
For example programs, see the stuff from Bill Cable:
DBeasy - https://dilwyn.theqlforum.com/database/dbeasyfo.zip
DBProgs - https://dilwyn.theqlforum.com/database/dbprogsf.zip
DBTutor - https://dilwyn.theqlforum.com/database/dbtutor.zip
Bill also wrote a column on Archive and the published it in a compendium document. I have it and will need to scan it one day.
Tim
NL_QL_Usr
Re: Archive pdf
Post by NL_QL_Usr »
Nice!!
You have rid off the holes ... :D
I will look at the examples to,
Thanks
Re: Archive pdf
I am in mid-scanning of the QL User Guide, and OCRing the resultant scanned image to a smaller PDF file.
I am only up to Abacus, so have not done Archive yet.
I will upload the resultant here when completed, or do you require it in parts?
swensont
Re: Archive pdf
Post by swensont »
Derek,
Check my PDF's and see if you like them. They are created from .DOC files (which I can send you). Might have you a bit in scanning and OCRing.
Tim
NL_QL_Usr
Re: Archive pdf
Post by NL_QL_Usr »
@ derek....
I only now saw your reaction.
I tried OCR with ocrmypdfgui on manjaro
It seems to be OK
Hopefully it helps....
at least I can edit the text now
archive_ocr.zip
(14.45 MiB) Downloaded 90 times
Re: Archive pdf
Thanks.
I do not use the GUI.
