QL Service Manual Update
This a thread for the update of the QL Service Manual.
I have drawn all the scanned diagram images into Libre Office grouped objects.
I have traced the component positions in the Issue 5 Layout diagram, just need to annotate the values. Which, I will validate from a UK Issue 5 board.
I have converted all the scanned image PDF files into a Libre Office Writer file, with diagrams drawn as grouped graphics line drawings.
I have the Issue 6 layout to do, which should be just a modification to the issue 5 board.
The Issue 5 & Issue 6 schematics have been updated in Xcircuit CAD software.
Maybe the Xcircuit files want to converted into a more up to date CAD package, like Kicad, is a large job, but PCB reproduction would easier.
The is outstanding tasks:
Change Issue 5 & Issue 6 Bill Of Materials to standard format
Microdrive schematic & Layout, including Head Board
Description of the non-UK QL board
Issue 7: Schematic & Layout drawings, Bill Of Materials.
Does the Service Manual, want to go onto Github?
Popopo
Re: QL Service Manual Update
Post by Popopo »
Hi Derek,
I think all you said is a must to do. :)
Moreover, it could be great in order to upgrade some thumbs for components, later modifications (for example to change memory type for another more accurate without +12V or +5V, etc etc.
So yes,
How would you like to organize the work?
I am learning to use KiCAD.
Such a pity we cannot use some developed like Tetroid did.
All the memory in the QL is 5V only.
The +12v is used for the RS232 transceiver, and the -12V is used for this chip also, plus it's used via 2 resistors (normally found on top of the ZX8302) to provide bias on the RAW read data lines.
I am not aware these voltages are used for anything else? +12v and -12V come from the 15V AC line via diodes and regulators.
The +9V from the power supply feeds the main regulator on the heatsink, the 2 microdrive boards, the external microdrive edge connector and the main edge connector where expansions go.
The MC 1377 is connected to +12V as well. No need to care if you don't use composite video or RF.
good spot :-)
I am continuing to progress the update of the QL Service Manual, a couple of questions:
On Issue 5 Layout and PCB TR10 is indicated next to IC37
but on Issue 6 boards, next IC37, thevtransistor to labelled TR 1
should the Issued 6 board TR1 be TR10?
Issue 5 show a Battery Connection, should this be LS for Speaker connection as on Issue 6 boards.
On Issue 5 boards - the LS connector is over near the LED connectors - so this should be left as battery.
I can only assume that TR1 / TR10 - perhaps a misprint of the silk screen?
TR1 is the loud speaker driver, I can't see a TR10 on either Issue 5 or Issue 6 circuit diagram.
Thank you for the updates, I will look into the changes in Issue 5 and 6.
I am using the updates to the schematics by Silvester, in Xcircuit. I did think about entering the schematic files into KiCad, posting this on Github, with the updates the the Service Manual.
I am in the process of drawing the MDV Headboard layout files, not fone in the original manual.
Popopo
Post by Popopo »
Derek_Stewart wrote: Sun Oct 13, 2024 6:13 pm Hi,
That is an amazing idea!
I am new in KiCAD, but if you want to share some part of the task, count on me.
In the message in the Wanted Section:
stephen_usher wrote: Mon Jul 07, 2025 10:25 am
As for the ULA, I don't know if anyone has reverse engineered that one. It's probably quite simple.
As part of my Service Manual update, I was looking at the Microdrive, giving a more detailed description of the Microdrive circuitry Headboard and detailing the parts with section on the ULA. I did wonder if the ULA could be reverse engineered.
