Gold Card Battery
Gold Card Battery
As the battery in my Gold Card no longer works, is it OK to just remove it and leave the Gold Card without a battery, in case the flat battery leaks?
I've never really relied on the battery backup clock anyway, so I probably wouldn't miss the battery, assuming the Gold Card can work without the battery installed.
Re: Gold Card Battery
dilwyn wrote: Thu Oct 12, 2023 9:36 pm As the battery in my Gold Card no longer works, is it OK to just remove it and leave the Gold Card without a battery, in case the flat battery leaks?
Yes that is okay.
my216
Post by my216 »
Out of interest, what is the purpose of the battery in the Gold Card? Is this like a CMOS battery?
ones' complement
Post by ones' complement »
Provides battery backed clock and a few unused bits in RTC chip hold settings for AUTO_TK2F1 (boot automatically as if you pressed F1 with TK2 extensions enabled, AUTO_TK2F2 for F2, AUTO_DIS cancels). Also SCR2EN/SCR2DIS for second screen and FLP_JIGGLE (fix for some drives). IIRC only 4 bits, but CMOS like settings :)
