qubata 3.10 what files should be on the formatted ide ??
i can not get it all to work despite hours of searching and reading .
i can not format a cf card with 3.10
WHAT am i doing wrong ??
- cf card does work under 1.56a , so it must be my not-knowledge of 3.10 .
can some one drop me an image of a working cf card ?
i found some info ;
can someone indicate to me where to download those files
Re: qubata 3.10 what files should be on the formatted ide ??
To create a QubATA 3.10 WIN drive, do:
WIN_FORMAT 3,4: REMark format quickly
WIN_DISK "INIT",1 : REMark Initial partition table
REMark Setup partitions, on device 1, partition 1, 256Mb in size
WIN_DISK "CREATE",1,1,256
WIN_DRIVE 1,1,1 : REMark link in WIN1_ from device 1,Partition 1
WIN_FORMAT 0 : REMark reset protection after format
When WIN drive is mounted with the WIN_DRIVE command, there will be no files on the drive.
The files details on screen shot, try looking on the QL Homepage.
Derek ,
Works !!
now to get the 4 software packages running .....................
Works !!
