-SOLVED- where to find the rom version in a rom dump file
techy
Post by techy »
Is there a specific rom address where the version of the rom can be found ?
Re: where to find the rom version in a rom dump file
There's a simple (but not very convenient) answer to this question: Nowhere specific.
The ROM version can be retreived from a running machine by executing the command PRINT VER$, but the string that is returned for this command is spread all over the place over different versions. If you only have the ROMs, your best bet is probably binary comparison to downloaded ROM images.
techy
Post by techy »
got the versions on screen but indeed wanted to know if i could find them in the rom-dump .
thanks for this answer !!
What QDOS Rom are you interested in?
There is JS disassembly and Minerva source code on the QL Home Page.
techy
Re: SOLVED where to find the rom version in a rom dump file
Post by techy »
derek i was curious about several eproms i had laying around ,
so i hoped for a way to pop them on the eprom burner and read them .......
now i have solved it by putting them all into one of my ql's :-)
