Hi all
I have both a gold card and trump card and wish to plug in a floppy drive I have some 3 1/4 drives but cant get them to do anything when plugged into the cards but I also have a 5 1/4 drive and works fine.
Do I need to do something to the 3 1/4 drives first or is there only certain ones the QL like.
Many Thanks
using floppy drives with gold card
- Chuggy Microdrive
- XorA
- Site Admin
Re: using floppy drives with gold card
Another 1/4 of an inch!
But if they are PC drives they will be DS1 and not DS0 that QL expects.
All future designs of floppy interfaces for the QL should have a bit flip jumper that just puts the drive select line through an inverter.
QL<->PC
Problem solved.
*writes in little black book*
QL<->PC
Problem solved.
All PC Flopy drives are setp as drive 1, with the Drive Selector set to DS1. This simplified manfacture of drives on PCs.
There is a twist in the floppy disk cable to alter the drive mapping.
On a QL FLP1=DS0, FLP2=DS1
To use a PC disk drive set to DS1, which be registered as FLP2, the floppy cable lines 10,11,12 need to twisted to so that 10-12, 11-11, 12-10, wil map the drive as FLP1
The Trump Card can access drives up to Double Density (720K), with a maximum of 4 drives.
The Gold Card can access drives up High Density (1.44Mb) and maybe ED disks, if the drives and disks are available.
I can supply suitable cable for using PC drives on a QL.
