SMFX - So Whatt? QL Sprite Record
hi there guys,
Ive set the new bar at 35 sprites in a single vbl while running a 1px scroller of 5px high and playing music! The previous record was at 17 sprites...
You can find the link to the binary https://www.pouet.net/prod.php?which=93405, or watch the Youtube video (captured from real hardware, but not at 50hz unfortunately), here: https://youtu.be/bS_Csjm01z0.
Try to beat diz!
Wietze
Try to beat diz!
Wietze
Re: SMFX - So Whatt? QL Sprite Record
Nice YouTube video.
I tried the SOHATT.IMG file on the Q68, which runs very nicely in 512x256 4 Colour mode.
Nice YouTube video.
that is unexpected; I would expect it to switch to 256x256; I am doing
The intended use is for Stock QL anyhow, but I can not explain why you are in mode 4.
wietze
or.b #%1000,$18063 ; set the 256x256 screen mode
wietze
Holy cow, that's an amazing achievement on stock QL
Waiting for ASM gurus like Norman or JanB to step up to the plate and try to beat that one
Thank you for bringing demoscene to the QL world, you rock!
- Aurora
Hi Folks,
The quoted YouTube video 3D animation of space vessels is very good.
It would be interesting to try to do it in Basic...
Steve.
Steve.
- NormanDunbar
- Forum Moderator
I don't "do" graphics!ppe wrote: Mon Jan 23, 2023 5:08 am ...Waiting for ASM gurus like Norman or JanB to step up to the plate and try to beat that one![]()
But it was very impressive!
Is the drawing somehow synchronised with the frame?
If yes, how?
If yes, how?
- Trump Card
The effect is double buffered, so a screen is completed before its displayed. The buffer switch is executed in the vertical blank vector, then the mainloop runs seperately from the vblank code to draw to the backbuffer. The mainloop in this case waits for the vblank to occur and have finished before it starts drawing to the buffer.dex wrote: Mon Jan 23, 2023 12:45 pm Is the drawing somehow synchronised with the frame?
If yes, how?
I dont know what you mean here; what do you mean with Sprite Toolkit?
For some other stuff I cobbled together a bmp to ql graphics format conversion (bmp in, assembly statements out).
For this sprite record stuff, the sprite graphic is analyzed and some optimal code generation has been applied. (bmp in, sprite masks and code out).
Kind regards,
Wietze
