Want: QL-SD drive
- mancity1961
- ROM Dongle
Want: QL-SD drive
Hi, anyone looking to sell a QL-SD drive as I desperately need one to complete my QL system. It will replace my Tetroid card which I will then sell as I no longer use it since getting an SGC.
- XorA
- Site Admin
Re: Want: QL-SD drive
Not all the QL-SD's work with SGC!mancity1961 wrote:Hi, anyone looking to sell a QL-SD drive as I desperately need one to complete my QL system. It will replace my Tetroid card which I will then sell as I no longer use it since getting an SGC.
Right, not out of the box, not the early ones. But you can make (all of) them work with a CPLD and ROM update. Obviously needs an EPROM programmer and a JTAG programmer. All the files needed can be found on Marcel's site.XorA wrote:Not all the QL-SD's work with SGC!mancity1961 wrote:Hi, anyone looking to sell a QL-SD drive as I desperately need one to complete my QL system. It will replace my Tetroid card which I will then sell as I no longer use it since getting an SGC.
Hi
I asked if I could build the QLSD v2, but was politely refused.
So I would have make the QLSD v1, maybe with a dual SD Card reader.
But I have a few projects to do some behind time: Q68, Oqtadrive, QLUB...
- mk79
Quite a revisionist statement. I wrote, literally "well, if you want we can talk about that, sure. But the problem with the current QL-SD is that there is much manual labor involved." and then a long text of what must be done. Your answer was "From your description, the construction of the QL-SD would be too hard for a PCB manufacturer, even if they worked how to do it, the cost would be high." That was it. Nobody refused you anything.Derek_Stewart wrote:Hi
Again, BS. The only difference between v1 and v2 are the CPLD files and those are openly available for everyone.So I would have make the QLSD v1, maybe with a dual SD Card reader.
- mk79
I have a few left but shipping stuff is so time consuming and annoying, especially outside the EU, that I haven't done it in a long time. Contact me in maybe two weeks, maybe I have finally got my stuff sorted out then.mancity1961 wrote:Hi, anyone looking to sell a QL-SD drive as I desperately need one to complete my QL system. It will replace my Tetroid card which I will then sell as I no longer use it since getting an SGC.
Sorry, I must be mistaken.mk79 wrote:Quite a revisionist statement. I wrote, literally "well, if you want we can talk about that, sure. But the problem with the current QL-SD is that there is much manual labor involved." and then a long text of what must be done. Your answer was "From your description, the construction of the QL-SD would be too hard for a PCB manufacturer, even if they worked how to do it, the cost would be high." That was it. Nobody refused you anything.Derek_Stewart wrote:Hi
- mancity1961
- ROM Dongle
Great thanks. I have been offered a ql-sd v1 would this be a good option for use with an sgc and Qemulator or would I be better off getting a v2 ?mk79 wrote:I have a few left but shipping stuff is so time consuming and annoying, especially outside the EU, that I haven't done it in a long time. Contact me in maybe two weeks, maybe I have finally got my stuff sorted out then.mancity1961 wrote:Hi, anyone looking to sell a QL-SD drive as I desperately need one to complete my QL system. It will replace my Tetroid card which I will then sell as I no longer use it since getting an SGC.
- mk79
v1 does not work with the SGC (which is the main reason v2 exists). You'd need a JTAG programmer plus special software to update it.mancity1961 wrote:Great thanks. I have been offered a ql-sd v1 would this be a good option for use with an sgc and Qemulator or would I be better off getting a v2 ?
To me, this statement is misleading. It is simple to upgrade v1 to work with SGC.mk79 wrote:v1 does not work with the SGC (which is the main reason v2 exists). You'd need a JTAG programmer plus special software to update it.mancity1961 wrote:Great thanks. I have been offered a ql-sd v1 would this be a good option for use with an sgc and Qemulator or would I be better off getting a v2 ?
From hardware point of view there is no blocking point.
