Whole PD Libraries
Whole PD Libraries
Thanks to the dedicated hard work of Martin Head, I've been able to upload two complete QL PD libraries to my website, one containing nearly 150 floppy disk images, the other about 480 disk images. Giving a total of over 600 floppy disk images of QL software, albeit there is a lot of overlap between the two libraries.
They are the old Qubbesoft P/D Libary and The Library.
Both available to download as either zipped sets of floppy disk images, or zipped QXL.WIN of disk images - use whichever suits you best. Please note the huge file sizes to download if on a slow or metered broadband connection though.
Both pages have a comprehensive list of the software, which you can download as PDF, ODT or Word files.
Get the entire Qubbesoft P/D library from: http://www.dilwyn.me.uk/qubbe/index.html or the mirror at http://dilwyn.theqlforum.com/qubbe/index.html
The Library files at http://www.dilwyn.me.uk/thelib/index.html or mirror at http://dilwyn.theqlforum.com/thelib/index.html
EDIT: Corrected link for Qubbesoft one (thanks Dex)
dex
Re: Whole PD Libraries
Post by dex »
dilwyn wrote:Get the entire Qubbesoft P/D library from: http://www.dilwyn.me.uk/thelib/index.html
Correct link is www.dilwyn.me.uk/qubbe/index.html
duncan
Post by duncan »
I have often wondered what happen to the PD QL libraries, and what gems they may contain. So many thanks to you Dilwyn and to Martin Head for compiling these collections.
Cheers
Duncan
Quick question. What is the Image Editor software? It looks like a Windows program but with menu items for the QL.
