Fast PLOT/DRAW Toolkit
In SBASIC/SuperBASIC Reference Manual Online there are some commands related to Fast PLOT/DRAW Toolkit
The commands in this toolkit are:
DRAW
PLOT
REFRESH
SCLR
SCRBASE
Where can I find the toolkit? I could not find it on DIlwyn's site
Re: Fast PLOT/DRAW Toolkit
Andrew wrote:In SBASIC/SuperBASIC Reference Manual Online there are some commands related to Fast PLOT/DRAW Toolkit
DRAW
PLOT
REFRESH
SCLR
SCRBASE
Don't know where that is - But the DIY Toolkit's Section G has fast screen plot and line commands that might serve you just as well.
tofro wrote:Don't know where that is - But the DIY Toolkit's Section G has fast screen plot and line commands that might serve you just as well.
Yes and No
Yes - as long as you want to PLOT on the visible screen.
But the Fast PLOT/DRAW Toolkit PLOT and DRAW commands are relative to the address defined/redefined with SCRBASE and allow background drawing.
Try my PD Toolkit disks - attached
It should be in there somewhere!
PDTOolkit Disks.zip
(1.24 MiB) Downloaded 107 times
RWAP wrote:Try my PD Toolkit disks - attached
Thank you Rich.
It seems that it's not on the disks.
In that case, I assume that this is one of the original toolkit descriptions added to the Reference Manual by the original German authors before I got involved....
I didn't have every toolkit which they had...
This is not the one asked for, but may come in useful. They are similar to LINE, LINE_R, POINT and INK but apparently up to about 20x faster
It's a FastLine article by David J Perry originally published in the old Popular Computing Weekly magazine on 15th January 1987. The article was added to Quanta Library at some point by Michael L Jackson.
fastline.zip
FastLine
(3.95 KiB) Downloaded 98 times
Thank you, Dilwyn
