Today I upgraded my QL computers to the latest SMSQ 3.38. While the upgrade went smoothly on my GoldCard QL and my Q68, it was not the case with my SuperGoldCard + Aurora station.
First strange behavior, when I try to configure the Aurora_bin file taken from the official SMSQ site, the config utility only list the SMSQ stuff to configure, while usually you can also see the wman + ptrgen stuff etc.
Also, when I LRESPR the aurora_bin file, the system crashes with a corrupted screen.
As anyone been successful in using SMSQ 3.38 on the Aurora ?
Regards
François
SMSQ 3.38 for Aurora does not work ?
- Trump Card
- mk79
Re: SMSQ 3.38 for Aurora does not work ?
I don't own an Aurora, but when I download the ZIP with the Binaries from Wolfgangs site I can configure all sections without problems.
Could it be that your _inf file has become corrupted?
And if there is no _inf file? I have never used that.pjw wrote:Could it be that your _inf file has become corrupted?
IIRC _inf is MenuConfig file for automatic updating.
I've just downloaded SMSQ 3.38 I'll try it on my Aurora/SGC set up.
David
If you use MenuConfig it produces a file called MenuConf_inf.RalfR wrote:And if there is no _inf file? I have never used that.pjw wrote:Could it be that your _inf file has become corrupted?
I have noticed on occasion that this file can, for some reason, become corrupted/confused. That produces strange effects on any subsequent editing of config items.
SMSQ v3.38 works fine on my SGC/Aurora setup.
MenuConfig applied to bin file reports everything : SMSQ 3.38, WMAN colours 2.09, WMAN 2.09, Hotkey2 2.31, Recent thing 1.00
BTW I never use _inf files
David
- Trump Card
Clearly my aurora_bin file was corrupted somehow. I will try again and report.
François
François
- Trump Card
Ok I figured out the problem, this is bad news.
The aurora_bin file was downloaded from Wolfgang site and went through many steps before ending on my aurora setup hard drive. So I checked the integrity of it along the path…
Ok on SMSQmulator i.e. config utility shows all config options
Ok on my Q68
Ok on my GoldCard SD card (transferred from Q68)
Ok on floppy disk (written by gold card) on both GC system and Aurora system
*** NOT ok on Aurora system Hard Drive ***
I have copied the file from floppy many times at different location on the HD and it end up corrupted every time
Starting SMSQE from the floppy disk works
Copying Aurora_bin from floppy to ram disk and starting SMSQE from there works
Copying Aurora_bin from floppy to my second HD and starting SMSQE from there works
Conclusion: my main HD has a problem… Corrupting files when writing them ? Or reading them ?
So far, all the old content, on this HD, seems to load OK, but how to be sure ?
Anyway, time to replace those old mechanical HD with something more recent…
François
Ok on my Q68
François
