SMSQ/E source tree.
prime
SMSQ/E source tree.
Post by prime »
Hi all,
Is there an easy way of purging all of the _rel _list etc files from the SMSQ/E source tree? At the moment I have it mounted on a dosX_ folder so can do it in windows, but it would be good if I could do the equivilent of "make clean" often does when building makefile based stuff.
Cheers.
Phill.
Re: SMSQ/E source tree.
prime wrote:<>Is there an easy way of purging all of the _rel _list etc files from the SMSQ/E source tree?<>
Try the dev8_extras_del_all_bas script.
