USB mouse adapter
desin
USB mouse adapter
Post by desin »
hello
found this in the Atari Forum
https://trumouse.com/product/trumouse-a ... e-adapter/
maybe worth a look
Greetings
Markus
Re: USB mouse adapter
desin wrote:hello
maybe worth a look
Greetings
Markus
I wonder if that would work with a QIMI interface, since I think (not 100% sure) that QIMI mice are Atari mice?
Qimi do indeed use Atari mice.
I was re-visiting Qimi lately. Was there a Gerber somewhere to make some? I know that someone in Germany had done some developments and there was someone else who had made a Qimi version for a PS/2 mouse.
Chr$ wrote:Qimi do indeed use Atari mice.
There was an attpt at producing a QIMI clone board with PS/2 option, there are Eagle Cad file, but no Getber files. But Gerber files can be reproduced in Eagle no problem.
I have 6 QIMI boards to repair with broken IC Pins, then was going make some more, withe the CAD files.
The clone QIMI board uses SMD components, so you will need to be able to do surface mounted soldering.
dilwyn wrote:I wonder if that would work with a QIMI interface, since I think (not 100% sure) that QIMI mice are Atari mice?
If the USB mouse is correctly converted into an Atari mouse port, it should work. It makes an Atari mouse compatible output, that is what QIMI awaits.
Ruptor
Post by Ruptor »
